Device will charge not not boot
The device has all the power LEDs off, but when it plugs in only the charging light lights up. I’ve tried replacing the motherboard and the battery. Any suggestions?
Questa è una buona domanda?
The motherboard to display cable was damaged.
Does your device have an hdmi port ? If so have you tried to attach it to a TV to see if your display electronics may be the issue?
I found that it was the cable from the motherboard to the display was damaged.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 7
Tutti i Tempi: 191
