Salta al contenuto principale
Il controller PS4 modello CUH-ZCT1. Rilasciato nel Novembre 2013 dalla Sony Computer Entertainment, la sostituzione della batteria da 3.7V di questo "six-axis" non è una riparazione complicata (N.B.: La guida di smontaggio NON è per questo modello)
387 Domande Visualizza tutte
Problems with my 2 controllers
So I’ve had both of my controllers since the release of the ps4 back in 2013. The controller i use most has a problem where i would plug it in to the ps4 to charge, then it would look up for no reason without moving the right stick. My second controller i use less, has problems where running feels sluggish, sometimes closes out of menus, and sometimes shoots my gun without me pressing R2. How can i fix these problems?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta Più Utile
Seems that dirt /dust has accumulated inside the Controllers. Cleaning the interiors of the Controllers should solve the problem.
Punteggio 1
One option would be to try resetting the controller. Under the L2 button there is a small hole on the back of your controller. Using an unbent paper clip, hold the button down for about 3-5 seconds. This will reset the controller. Now plug your controller into your PS4 and re-sync it for a successful reset. If this doesn’t work, then definitely try cleaning it out to see if that resolves the issue.
Punteggio 0
Aggiungi la tua risposta
Lance Beltrano sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 29
