Salta al contenuto principale
This device is a personal paper shredder manufactured by Fellowes, Inc. in 2005. The shredder has the capability of shredding 7 sheets of paper at once as well as credit cards, identification cards, and cards likewise of the same thickness.
Where can have my Fellowes W11C repaired?
The sensor that turns shredder on is broken, so when I stick a piece of paper in the machine will not start. Where can I get this shredder repaired? Replacement part? Can I repair this myself?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
@x41perch take a look at this guide. Even so not specifically for your model, the shredders should work in pricipal the same Fellowes T7CM Trigger Sensor Replacement
Take pleny of pictures when you take yours apart and you can post those with your question Aggiungere immagini ad una domanda Creating a new guide would even be better https://www.ifixit.com/Guide/new
Immagine iFixit
Guida
Difficoltà:
Molto facile
2 - 5 minutes
Immagine Fellowes T7CM Trigger Sensor
Guida
Difficoltà:
Facile
1 minute
Punteggio 1
Aggiungi la tua risposta
Bob Malwitz sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 10
Tutti i Tempi: 674
