Salta al contenuto principale
iPhone di quarta generazione. La riparazione è semplice, ma il vetro anteriore e l'LCD andranno sostituiti insieme. GSM / 8, 16, or 32 GB di memoria / Modello A1332 / Nero e Bianco.
iPhone in boot loop when charging
Hey!
So my Iphone 4 fell in water and now it is in boot loop. It actually doesn’t work without charging and when plugged into charge, it starts to boot loop. I don’t need the phone, but I have a lot of old pictures of my children in it. I tried Itunes update( I can get it in itunes mode) and all the popular programs that recover files or flash the Iphone with keeping the files. I tried the home button and power button techniques but nothing seems to work.
Can someone tell me what actually the problem is?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
its probably because of a loose battery connection if its just rebooting whilst plugged as to boot a battery must be plugged in so take the back off and check the connection
search battery replacement for iPhone 4 or 4s in ifixit and it should pop up its fairly simple all you need is a 1.5 Philips i believe
Punteggio 0
1 Commento:
Thank you for your answer! And is there no possibility to get the pictures that are in the Iphone?
da
Preparati per le riparazioni future
Acquista tutti
Aggiungi la tua risposta
Jeck Hollaus sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 276
