Salta al contenuto principale
Introdotto il 19 settembre 2014, questo iPhone con schermo da 4,7" è la versione più piccola dell'iPhone 6 Plus. Identificato dai numeri modello A1549, A1586, and A1589.
How to get iPhone to turn back on?
I left my iphone and put it to sleep, and then half an hour later, I went to turn it back on again and it didn’t respond. During that time, the phone was in my pocket doing absolutely nothing. I have tried all of the solutions that I found online including the force restart, etc. I have tried plugging it into my computer to see if it recognizes it, and it doesn’t. I have tried charging it and it still does not do anything.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Replace battery first and check that you can find the clue what you have to do.
Punteggio 0
Preparati per le riparazioni future
Acquista tutti
As Akash suggested, if you can remove the battery it will help. I would lift the screen and disconnect the battery, then plug the phone into a computer with iTunes installed. If the phone boots up with the battery disconnected, then the battery is likely the problem: follow this guide to replace it. If it doesn’t boot up, you should hopefully still get an error message of some description from iTunes. The error message should give you a better indication of what is wrong.
Punteggio 0
2 Commenti:
An iPhone will not boot without a battery...
da
@refectio problem here is one cannot upvote the comment :P
da
Aggiungi la tua risposta
Aryan Mistry sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 55
