Salta al contenuto principale
The LG X Power is a 4G LTE smart phone that was released on August 2016. This model has a 16 GB memory with an Android operating system.
battery sign with a question mark in it
When i plug in my phone to charge im just getting a battery sign with a question mark in the middle of it? what does that mean?
Questa è una buona domanda?
Punteggio 12
13 Commenti
My lg q6 alpha is showing the red question sign on the screen I don't what to do
da
What do I need too do if my phone want come on and only show a ? Mark
da
my lg is not turning on
da
I have a lg Stylo phone that I replaced the charging port in which was fairly easy. After getting the phone back together I plugged it in and all it will do is flash the battery sign with a question mark in the middle of it. How do I fix this?
da
I have the same problem in my lg v10 question mark after connecting the charger
da
Mostra altri 8 commenti
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Try a different cable, and charger transformer (plug into pc to charge. A question mark I've seen to be a few different things. Dust in phone charge port, battery took a crap. Or bad charger/transformer
  1. Clean charge port. And cable connection
  2. Replace charger/cable
  3. Replace battery/charge port
Punteggio 5
5 Commenti:
OK thank you
da
Hold finger on Questiomark for while..
da
still not working..... im getting mad
da
1 ; either try cleaning battery
2 ; let your phone get cool
3 ; idk
da
If your lg k20 gives you a battery with a red question mark in it 😭😭😭 do a replacement with the battery my grandma's worker at work named Sam said it needs a new battery even with a 2 boxes one with the lg and one with a red question mark ❓ that
da
Parti e strumenti popolari
If u can't turn on the phone after a few seconds of holding down the power button, and the ? Battery when appears don’t disappear when plugging it in. Its probably either the charger or ur phone got overheated where it needs time to cool down for a bit. Once ur able to turn it on by the power cord then its fine. Just keep it out of intense heated places and keep it cool.
Punteggio 2
2 Commenti:
If you get anew battery note to remove the stick on the 4 battery connectors
da
im getting the red question mark. i just installed a new battery. please clarify "remove the stick" on the battery connectors. thanks
da
Aggiungi la tua risposta
Jonathan sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 44
Ultimi 30 Giorni: 162
Tutti i Tempi: 56,198
