Salta al contenuto principale
A Chromebook built to withstand drops, spills, and sudden shock and designed for the classroom and for users who spend lots of time on the road.
How does this panel come out?
[image removed]
This panel has a clip that won't come loose.
Edit: The rear panel has no clip, I was mistaken. There was nothing to remove.
[image removed]
I'm trying to get the hard drive out because I lost the charger and I have something to turn in tomorrow… anyone know how to get it out?
Questa è una buona domanda?
Punteggio 0
2 Commenti
what is the exact model number?
da
Because this is a Chromebook then all your work will be in Google Drive, so I think it might be easier to access it from another device. Just sign-in with your gmail address and all your work should be available.
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Minater 247  Lenovo 11e the 20gf version does not have a hard drive. It has a eMMC (embedded Multi Media Card ) which is soldered to the motherboard. Nothing you can remove to get to your files. you will need to get a proper charger.
Punteggio 3
Aggiungi la tua risposta
Minater 247 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 4
Tutti i Tempi: 358
