Salta al contenuto principale
Un Chromebook costruito per resistere a cadute, versamenti di liquidi e urti improvvisi, progettato per l'ambiente scolastico e per gli utenti che trascorrono molto tempo in viaggio.
How does this panel come out?
[image removed]
This panel has a clip that won't come loose.
Edit: The rear panel has no clip, I was mistaken. There was nothing to remove.
[image removed]
I'm trying to get the hard drive out because I lost the charger and I have something to turn in tomorrow… anyone know how to get it out?
Questa è una buona domanda?
Punteggio 0
2 Commenti
what is the exact model number?
da
Because this is a Chromebook then all your work will be in Google Drive, so I think it might be easier to access it from another device. Just sign-in with your gmail address and all your work should be available.
da
Aggiungi un commento
1 Risposta
Soluzione prescelta
Minater 247  Lenovo 11e the 20gf version does not have a hard drive. It has a eMMC (embedded Multi Media Card ) which is soldered to the motherboard. Nothing you can remove to get to your files. you will need to get a proper charger.
Punteggio 3
Aggiungi la tua risposta
Minater 247 sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 2
Ultimi 30 giorni: 20
Tutti i Tempi: 634
