Salta al contenuto principale
GSM iPad 2 with 16, 32, or 64 GB of storage, and a Dual Core A5 Processor. Model Number A1396. Repair is complicated and requires heat and prying.
Why is the power button not working?
After a digitizer and wifi chip replacement my power button and i also think volume stopped working?
Questa è una buona domanda?
Punteggio 0
1 Commento
Is this a hardware problem?
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
The iPad 2 has a ribbon cable in the top-right corner that’s responsible for the power button, volume, and mute slider functionality. This ribbon is frequently stuck to the digitizer, and is easily torn if you don’t know it’s there, and don’t take active measures to gently seperate said cable form the digitizer during repair.
Edit: Yes it’s a hardware problem.
This iFixit Guide covers replacing that cable: iPad 2 GSM Volume and Power Button Cable Replacement
Punteggio 2
Parti e strumenti correlati
Acquista tutti
Aggiungi la tua risposta
Scott P. sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 94
