Salta al contenuto principale
Third generation of iPad, featuring 4G capabilities, released on March 16, 2012. Model number A1430. Repairs require heat and careful prying.
Replaced digitizer starting to fail
iPad3. Last year I replaced my digitizer/screen with a new iFixit digitizer. Now, the left edge of the digitizer is dead to touch. The dead zone started about 1/8” wide and has grown to about 1/4” wide. Meanwhile the right edge is doing the same thing, about 1/8” wide.
I keep it in a wraparound case and I noticed the left edge is starting to come unglued. Is this related? Can I fix this somehow, or do I need another digitizer?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Hi @wolfharper ,
I suggest that you contact ifixit regarding the problem with the touchscreen “dead zones”. It never hurts to ask
According to their iPad 3/4 Screen Digitizer parts information, there is a lifetime warranty on their parts
Immagine Replace a scratched or cracked front glass screen digitizer panel. This part is compatible with a 3rd or 4th generation retina display model iPad.
Prodotto
$24.99
Punteggio 2
Try re plugging the screen back in. If it doesn’t work, you will have to replace the digitizer again . Let me know results … thank you
Punteggio 0
1 Commento:
Yeah digitiser needs to be replaced. I always add b7000 glue on bottom left and clamp down for a while to avoid this problem of the glass getting pushed up via the cable.
da
Aggiungi la tua risposta
Wolf Harper sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 7
Tutti i Tempi: 114
