Salta al contenuto principale
Rilasciato il 19 settembre 2014, è la versione con schermo più grande (5.5") dell'iPhone 6.
What is wrong with my phone?
In the past couple weeks, my phone battery has been acting weird, restarting itself at complete random times, turning off at 40%, etc. The screen on the left side was also popping up, a pretty large amount for the screen and so I figured it was a swollen battery. I have an IT person in my family who fixes computers for a living so i bought a $30 repair kit off amazon and had him replace it. Immediately after the phone still didn’t work right, it started restarting itself and the battery level would change almost everytime it did. I left it in to charge overnight and it only went up 3%, and when I unplugged it to go downstairs and plug it in, I tried to use it and ever since then it consistently restarts after maybe 2 minutes of use. Been plugged in ever since and hasn’t gone up any at all. Also just inspected the same left side of the phone that I had problems with before and it has gone up already even thought itwas completely level again after changing the battery.
Questa è una buona domanda?
Punteggio 0
1 Commento
I would also just like put emphasis on the fact that my phone was resetting itself the same way before changing batteries; just not as often, so I'm more convinced it's not the new battery.
da
Aggiungi un commento
3 Risposte
Risposta Più Utile
Keep connected iPhone to charger and update iPhone to latest ios version. Try another battery on your iPhone. If iPhone work fine then there is battery issue.
Punteggio 1
2 Commenti:
it can't stay on long enough without restarting to update it. I plan on switching the battery to a different iphone same make and see if the battery works in that one.
da
Yes this will clear weather problem is related to battery or hardware or it is related to software os problem. Try other working battery then check.
da
It is possible that the repair has failed. I would suggest replacing it with an OEM battery
https://www.replacebase.co.uk/apple-ipho...
Sostituzione batteria dell'iPhone 6 Plus
Punteggio 0
First think you have to do is check battery health in setting and if phone does not show battery health then replace battery at first point and if its same not show battery health after battery replacement then there is problem in your motherboard.
Punteggio 0
Aggiungi la tua risposta
Kasey L Baars sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 79
