Salta al contenuto principale
La versione Lite del cellulare Huawei P10 del 2017. Rilasciato nel marzo 2017, ha una doppia fotocamera posteriore, sviluppata in collaborazione con Leica. Può avere 32 o 64 GB di memoria interna e sei differenti finiture esterne. Il numero di modello è WAS-LX1A.
Why is my device not getting on and only does when plugged in charge
hello guys my huawei p10 lite doesnt get on when i press the on button the only it gets on and keeps on restarting is when i plug in the charger, and sometimes display huawei eRecovery then it resarts after some few seconds. the charging indicator does not get on
Questa è una buona domanda?
Punteggio 3
1 Commento:
Hi. I don't fix phones but am just also looking for a solution for one of mine now.. It jus started doing the same.. Did you find a solution for yours or not, is the problem fixable??? Thinking about replacing the battery... Is it worth it??
da
Aggiungi un commento
2 Risposte
Seems like a battery issue. It doesn’t want to keep a charge, so it’s time to change the battery (or change your phone in shop, if it’s still under warranty).
Punteggio 0
4 Commenti:
but i bought the battery recently it doesn't have six months
da
That can happen with everybody. Just got unlucky, whatever, fixing it and moving on.
da
oh okay thanks i will replace it
da
Good luck, dude. Godspeed!
da
Preparati per le riparazioni future
Acquista tutti
If you are still looking for an answer , a solution might be USB Charging Port Charger. For me it was a short circuit in the charging port that was caused from the broken antenna cable. If that's not the issue then unfortunately it must be a motherboard issue.
Punteggio 0
1 Commento:
My huawei p10lite fell yesterday and it is in erecovery mode..it cannot charge..what can be the issue
da
Aggiungi la tua risposta
Lapologang Matshelane sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 12
Tutti i Tempi: 930
