Salta al contenuto principale
ASUS H110M-D Can't find IDE mode in BIOS.
Hi Guys!, I just want to ask if Asus H110M-D Mother Board supported the IDE mode in the Bios.
thanks for the help guys!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
If you need to configure or set up your computer motherboard’s CMOS, BIOS, or chipset, see the Motherboard CMOS Configuration and Setup page for instructions.
I believe the setting you want is to set “SATA Mode” to “AHCI.”
Punteggio 1
2 Commenti:
Yes how to do it? because there is no setting in BIOS of IDE and AHCI only SATA.
da
It took some digging, but this is what I found:
Because the Intel H110 chipset only supports AHCI mode, there might not be an additional option about SATA mode under BIOS.
da
Aggiungi la tua risposta
Joebert Lazano sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 21
Tutti i Tempi: 3,818
