Salta al contenuto principale
Repair guides and support for hair irons, also known as hair straighteners.
How can I fix a short in the wire?
I have a Linea pro flat iron with the pants clip. There's a short in the wire and I have no idea where to get it fixed.
Update (04/01/2019)
How could I fix one myself. No wires are exposed. I could take a picture
Questa è una buona domanda?
Punteggio 0
1 Commento
I believe it is where the wire connects. It can swivel and I think it's there. It's a old Linea pro leopard print.
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
See if either one of these guides will give you a clue as to how to open it up to check it for burned components. Use a multimeter to test it for continuity to find the problem.
CHI Original Circuit Board Replacement
Hot Tools HPK12 Cord Replacement
Immagine Hot Tools HPK12 Cord
Guida
Difficoltà:
Facile
10 minutes
Immagine CHI Original Circuit Board
Guida
Difficoltà:
Difficile
1 - 2 hours
Punteggio 3
hello Sora, if you fix it your self it would be cheaper on you. For a shop to fix you would want to compare cost of product to repair cost. Most likely the short would be at the point of where the wire comes into the main unit being pulled out or to short in wire length overall.
Punteggio 1
Aggiungi la tua risposta
Sora Kururugi sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 8
Tutti i Tempi: 943
