Salta al contenuto principale
CHI Original Circuit Board Replacement
Cosa ti serve
  1. CHI Original Circuit Board Replacement, Hinge Spring: passo 1, immagine 1 di 2 CHI Original Circuit Board Replacement, Hinge Spring: passo 1, immagine 2 di 2
    • Insert a nylon or metal spudger under the plastic CHI spring covers. Pry them up to pop them off. Do this for each side.
  2. CHI Original Circuit Board Replacement: passo 2, immagine 1 di 1
    • Remove the .53" long screw from the hinge pin.
  3. CHI Original Circuit Board Replacement: passo 3, immagine 1 di 1
    • Remove the hinge pin.
  4. CHI Original Circuit Board Replacement: passo 4, immagine 1 di 1
    • Separate the two halves of the CHI Original.
  5. CHI Original Circuit Board Replacement: passo 5, immagine 1 di 2 CHI Original Circuit Board Replacement: passo 5, immagine 2 di 2
    • Remove the spring pin with a pair of pliers or tweezers.
    • Remove the spring.
  6. CHI Original Circuit Board Replacement, Power Cord: passo 6, immagine 1 di 2 CHI Original Circuit Board Replacement, Power Cord: passo 6, immagine 2 di 2
    • Remove (2) .31" Phillips head screws from back cover.
    • Remove cover.
  7. CHI Original Circuit Board Replacement: passo 7, immagine 1 di 1
    • Gently pull upwards on the connection point and disconnect the power cord.
  8. CHI Original Circuit Board Replacement, Circuit Board: passo 8, immagine 1 di 3 CHI Original Circuit Board Replacement, Circuit Board: passo 8, immagine 2 di 3 CHI Original Circuit Board Replacement, Circuit Board: passo 8, immagine 3 di 3
    • Remove the (2) .27" Phillips head screws on each half of the CHI Original.
  9. CHI Original Circuit Board Replacement: passo 9, immagine 1 di 3 CHI Original Circuit Board Replacement: passo 9, immagine 2 di 3 CHI Original Circuit Board Replacement: passo 9, immagine 3 di 3
    • Remove the covers on both halves.
  10. CHI Original Circuit Board Replacement: passo 10, immagine 1 di 1
    • Remove (2) .15" Phillips screws from the circuit board.
  11. CHI Original Circuit Board Replacement: passo 11, immagine 1 di 2 CHI Original Circuit Board Replacement: passo 11, immagine 2 di 2
    • Desolder all points of contact between the circuit board and wires on the ceramic heating elements.
Conclusione
Eric Knigga
Membro da: 08/23/17
215 Reputazione
2 Guide realizzate
IUPUI, Team S1-G2, Freund Fall 2017 Membro di IUPUI, Team S1-G2, Freund Fall 2017
IUPUI-FREUND-F17S1G2
4 Membri
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 30
Tutti i Tempi: 2,986
