Salta al contenuto principale
A revival of the original Nokia 8110, this phone was released in 2018, also known as The Matrix Phone.
How can I remove wifi chip?
Hello,
I want to buy my son the new banana phone, but I cant trust him with wifi accessibility,
is it possible to remove the wifi chip on the phone?
Thanks,
Mendel :)
Questa è una buona domanda?
Punteggio 0
1 Commento
אני לא מצליח לצפות בסרטון הדרכה אם אפשר לשלוח לי אותו
Google translate:
I can't watch a tutorial video if it can be sent to me
email address removed to prevent spam being sent- moderator
da
Aggiungi un commento
3 Risposte
Risposta Più Utile
It's an easy teardown but not much for information in regards to a chip for wifi. Most parts are soldered to motherboard.
I'm not sure what it is capable of, but an app is probably more of what you need. There is one I've used “screen time parental controls” which controls screen time. App access, sees browsing history, and you can shut down usage if need be by schedule or instantly via your
Nokia 8110 4G Teardown
Punteggio 3
Parti & Attrezzi Popolari
Hi @nhfh
Check if the mobile data setting has been selected for the correct SIM card
Go to Settings  >  Network & Connectivity  >  SIM Manager.
Choose which SIM to use for mobile data, select  Data , and select  SIM1  or  SIM2
Punteggio 1
You cannot remove WiFi chip. It's SoC so everything is in one chip which is named Snapdragon 205.
Punteggio 0
Aggiungi la tua risposta
Mendel Goldstein sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 592
