Salta al contenuto principale
Shark Navigator Lift-Away (NV352) is a type of vacuum that functions on both hardwood and carpet with a lift-away feature. The NV352 includes several cleaning attachments. The vacuum was released in 2008 and is often referred to as the Shark Navigator Lift-Away.
Why does my rotating brush stop spinning when it is in use..
I replaced belt, rotating brush on the vacuum. It starts rotating again after I put vacuum in upright position and back until vacuum position. It runs for a short period then stops rotating . It does this continuously for as long I’m using the vacuum.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
If your Shark vacuum stops moving suddenly during use, see the Shark ION Robot R75 Stops Moving Unexpectedly problem page for possible problems and solutions.
Punteggio 0
Preparati per le riparazioni future
Aggiungi la tua risposta
pick608 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 6
Tutti i Tempi: 199
