Salta al contenuto principale
AC power adapter for MacBook, MacBook Pro, and MacBook Air. Uses a self-aligning magnetic connector that disconnects safely when tugged. First-generation (2006-2012) MagSafe chargers have a slightly thicker, L-shaped connector. Available in 45 W, 60 W, and 85 W versions.
My adaptor is not Working.
i have a Magsafe 60w. i dissemble it to check it from inside . i have found a one 8 pin ic is burnt out and one resistance. now help to repair or reuse this again for my macbook pro.
Questa è una buona domanda?
Punteggio -1
2 Commenti
do not try to fix the power supply fro your magsafe just buy new one
da
@baboba...What happens if you are in an area where you can not just buy a new one? Is it possible to repair it?
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
I found a video for doing the repair. Warning - It's ugly : http://www.youtube.com/watch?v=20vLvXUfr...
I really recommend replacing it.
Punteggio 5
3 Commenti:
i cannot watch it it said contained a malformed video ID.
da
Here's about ten videos on fixing it: http://www.youtube.com/watch?v=20vLvXUfr...
da
Preparati per le riparazioni future
I am just going to saythis
you need a dremel to open it and clean up the burrs on the case
you need a good glue to seal the case after and still make it look remotely descent after
In all honesty, replace it if you can, ONLY fix it if you cannot afford a new one and if you do, follow my tips above to make it as clean as you can
Once again, you will need a thin dremel tip to open it and you will need to solder, and after that, a grinding wheel to get rid of the burrs after as much as you can and duct tape or super glue
Punteggio 0
1 Commento:
Any idea of anything fixable on the inside?
da
Aggiungi la tua risposta
SIMRAN sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 15
Tutti i Tempi: 2,582
