Salta al contenuto principale
Released September 2011 12.2 MP Digital Camera with 7.1x Optical Zoom NIKKOR ED Glass Lens and 3-inch Vari-Angle LCD
4 Domande Visualizza tutte
Flash on my Nikon P7700 camera will not pop up.
The flash on Nikon P7700 is stuck. It will not pop up.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Thanks James. In my case, the flash does pop up after a few tries. I have to release the latch with a jerk. That helps the flash to pop up. Looks like there is a spring under the flash which has lost its tension with time or maybe the latch might be worn out now.
Punteggio 0
My Kodak has the same problem. I think the little relay that unlatches it is just a little off adjustment, so I give it a little help with my fingernail sometimes. Either yours is out of whack due to wear or misalignment (damage?), or just permanently broken.
Punteggio 0
Aggiungi la tua risposta
sb_singh sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 479
