Salta al contenuto principale
The Ram line was redesigned for the 1994 model year. Development on a second generation began in 1986, ending in late 1992.
Computer malfunction, reset possible?
The main snap together wiring was removed while the engine was running. Now runs super retarded. can I reset?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
With the engine off, cycle the ignition on and off 3 times quickly leaving the ignition on the last time. The odometer will display the codes in the PCM. f the codes are not active you may be able to clear them with the odometer reset button. If this does not work you will need a OBD scan tool to clear the codes.
Punteggio 0
Parti & Attrezzi Popolari
Aggiungi la tua risposta
Jack Heringer sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 7
Tutti i Tempi: 180
