Computer malfunction, reset possible?
The main snap together wiring was removed while the engine was running. Now runs super retarded. can I reset?
Questa è una buona domanda?
With the engine off, cycle the ignition on and off 3 times quickly leaving the ignition on the last time. The odometer will display the codes in the PCM. f the codes are not active you may be able to clear them with the odometer reset button. If this does not work you will need a OBD scan tool to clear the codes.
Ultime 24 ore: 0
Ultimi 7 giorni: 3
Ultimi 30 giorni: 33
Tutti i Tempi: 619
