Salta al contenuto principale
The Western Digital My Passport Ultra is a USB 3.0 portable storage device with capacities from 500 GB up to 5 TB.
WD My Passport Ultra Not Detected
I have almost 1.5TB in this drive. Can still my WD My Passport Ultra be fixed? Or I just need the files within my hard drive.
- My WD My Passport Ultra was not showing in [My Computer].
- My WD My Passport Ultra cannot be initialized due to hardware error.
- My WD My Passport Ultra still not showing in [My Computer] using other USB Cord.
- My WD My Passport Ultra was shown in [My Computer] depending on how it was inserted to a USB Port but i could not open any folder/file within the drive.
Questa è una buona domanda?
Punteggio 2
2 Commenti
i have problem with it
da
I need a program that can restore the wd passport
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
The drive being visible has multiple parts:
1) The USB interface must be working in order for the computer to recognize that there is a device at all.
2) The "driver" board on the disk must be somewhat working in order for the system to realize that the device is a disk and exists.
3) The actual spinning rust (called a disk) must be readable in order to store or retrieve files.
I think you may be having a problem with the USB interface and/or the "driver" board of the disc itself. Without seeing the device and poking around a bit, I can't be sure.
Dan
Punteggio 1
1 Commento:
Does it mean that i need to bring this on iFixIt so they could check it out?
da
Preparati per le riparazioni future
Aggiungi la tua risposta
Serniel Barbosa sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 8
Tutti i Tempi: 1,801
