Salta al contenuto principale
Lanciato il 25 settembre 2015. Modello A1687/A1634. Si ripara in modo simile alle generazioni precedenti, richiede cacciaviti e strumenti di apertura. Versioni GSM o CDMA /16, 64, 128 GB / Oro rosa, Oro, Argento, Grigio siderale.
Stuck in Bootloop before and after replacing battery and Lightning con
Here is my orig. post
With my 6s+ the battery went from 90% to 1% and restarted itself over and over, and then wouldn't charge. I thought the battery was to blame so I replaced it. It worked good for a day and then its back to 1% and restarting. Now, its stuck in a boot loop were it will go between quickly flashing the backlight and flashing apple logo. Any ideas? Ive tried to restore but it doesn't stay on long enough.
Since then ive replaced the lightning connector, unplugged the camera, and tried to restore with screen unplugged. But my phone still bootloops. And, when i try to restore it it goes into bootloop before i can do anything.
Can someone please help
P.S. when i restore i get various errors, 4013, 2009, etc.
Questa è una buona domanda?
Punteggio 1
1 Commento
Also, i should mention. It was on ios 11.1 and jail broken.
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
You'll need to take the phone to a reputable repair shop that does board-level repairs on iPhones.
I'm guessing along the lines of faulty Tristar (Charging chip) / PM IC (Power management chip).
Punteggio 1
2 Commenti:
In my city there are 2 stores. Neither of which do board-level. The nearest apple store is about an hour away. Should i just save up for a new one?
da
Wait is it only boot looping and getting stuck at apple logo when at 1%? That does certainly sound like charging chip issue.
You may want to consider doing a mail-in to a shop like iPad Rehab:
http://mendonipadrehab.com/
Buying a new iPhone will cost quite a bit and the one I linked has a 'no fix = no fee' guarantee.
da
Preparati per le riparazioni future
Acquista tutti
I had the same issue but I changed the battery and Restored the Device to factory settings.
its working now
Punteggio 0
4 Commenti:
I cant even get the phone to boot. Its in recovery/boot loop
da
if you plug it into the computer would start to boot loop ?
if so then hard reset it and seconds after hold down the home power ..
da
When i plug it in it either bootloops or prompts for recovery. Every time i try to recover, it goes back into a bootloop during "Waiting for iphone"
da
Aggiungi la tua risposta
Michael N sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 213
