Salta al contenuto principale
The Nikon Coolpix L32 is a digital camera that was released in 2015 by the Nikon Corporation.
13 Domande Visualizza tutte
Why is it turning off to prevent overheating?
My nikon Coolpix l31 is turning off to prevent overheating in under 30 seconds of having turned it on. This started about a week after I got it. Haven't used it much since, got it about 2 years ago.
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
2 Risposte
the likely answer is one of two things. A short on the board, or a bad internal resistance of the battery. If you replace the battery, and it doesnt fix the issue, the most likely scenario is that a board level short is drawing too much current. replacing a logic board is usually not worth the cost of the repair, and i would suggest replacing the device at that point.
Punteggio 0
Nikon l31 modal overhiting problem
Punteggio 0
Aggiungi la tua risposta
Kole White sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 12
Tutti i Tempi: 969
