How to replace radiator
how fixed water tank
Questa è una buona domanda?
Here's a video on how to do it:
While this video is pretty decent, it's for the 2006 model which has some significant differences. I'll have to verify on a 2009, but IIRC the top core support on the 2007 and later doesn't just pop off with 4 screws as shown here.
Did you check for any coolant stains around the base or seams of the radiator or around the radiator neck etc?
If around the base of the radiator you may have a leaking radiator core or if on the neck of the radiator, a faulty radiator cap.
Get the cooling system pressure tested to see if the leaks show up.
Ultime 24 Ore: 3
Ultimi 7 Giorni: 16
Ultimi 30 Giorni: 74
Tutti i Tempi: 10,289
5 Commenti
what year is the santa fe
da Jimfixer
A 2012 Hyundai Santa Fe, have radiator leak, replaced top hose already, still leaking. Can't find a Youtube video for 2012 Santa Fe.
da lilirishpol
Just to know how to repaired
da Esam
How to fix or replace radiator
da Martin Caine
@Martin Caine
What is the year model of the vehicle?
What's wrong with the radiator?
da jayeff
