Salta al contenuto principale
Released in June 2017 as a successor to the Surface Pro 4. Also known as Microsoft Surface Pro 12.3". Model number: FJT-00001.
Using Surface Pro 4 (1724) LCD screen to replace Surface Pro 5 (1796)
Hello,
I have a Surface Pro 5 with a cracked screen. I also have a Surface Pro 4 LCD laying around and wanted to know whether I could use the LCD for Surface Pro 4 to replace this screen. The connectors look very similar in pictures, but I can’t open it up to find out as I would prefer to use what I have until I’m ready to spend $230 for a new screen...
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Never mind. Found the answer. Thank you
Punteggio 0
2 Commenti:
So, what's the answer? I would love to know if they're compatible.
da
No way. The cable hookups are in different locations.
da
Preparati per le riparazioni future
Acquista tutti
Risposta Più Utile
The answer is you cannot use a Surface Pro 4 on a Surface Pro 5. The cables for the LCD and N-Trig chip are different.
Punteggio 1
Aggiungi la tua risposta
Quan Hoang sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 12
Tutti i Tempi: 1,953
