Salta al contenuto principale
Released in June 2017 as a successor to the Surface Pro 4. Also known as Microsoft Surface Pro 12.3". Model number: FJT-00001.
51 Domande Visualizza tutte
Using Surface Pro 4 (1724) LCD screen to replace Surface Pro 5 (1796)
Hello,
I have a Surface Pro 5 with a cracked screen. I also have a Surface Pro 4 LCD laying around and wanted to know whether I could use the LCD for Surface Pro 4 to replace this screen. The connectors look very similar in pictures, but I can’t open it up to find out as I would prefer to use what I have until I’m ready to spend $230 for a new screen...
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Never mind. Found the answer. Thank you
Punteggio 0
2 Commenti:
So, what's the answer? I would love to know if they're compatible.
da
No way. The cable hookups are in different locations.
da
Risposta Più Utile
The answer is you cannot use a Surface Pro 4 on a Surface Pro 5. The cables for the LCD and N-Trig chip are different.
Punteggio 1
Aggiungi la tua risposta
Quan Hoang sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 7
Tutti i Tempi: 1,787
