Salta al contenuto principale
The Asus X200MA is a portable touchscreen laptop with an 11.6" display. This device was manufactured in 2014 and is also identified as Asus X200MA-RCLT07.
Wi-Fi driver not there? Help
Alright so first off, I don't know much about computers so you guys might have to kind of walk me through this one. Now, basically what is happening is that my laptop (Asus X200MA running Windows 10) is missing a driver... or at least I think. Where it used to show the Wi-Fi icon on the taskbar it now just shows an Ethernet symbol with no connection. I've tried everything to fix it. Nothing works. Does anyone know how I can fix this? I already tried downloading the wireless connection driver from the Asus website. It installed, I restarted my laptop and still nothing... i just want to use mynlaptop and not have to pay to get it fixed...
P.s I am willing to factory reset it if needed. I already did and it still dis nothing.
P.p.s it does work when I use an Ethernet cable...
Questa è una buona domanda?
Punteggio 0
2 Commenti
Hi Dburns, Had you tried checking on your device manager, to check if it it has been detected on your computer?
Right click on "This PC" select properties,
Click on Device Manager on the Left
Expand Network Adapters.
Do you See any wireless card detected there?
da
Hi Augustine. Thank you for the reply. I have tried that and it didn't show the Wi-Fi adapter. Only the Ethernet and LAN ones I believe were there.
da
Aggiungi un commento
3 Risposte
Soluzione Prescelta
Hi,
If it doesn't appear in Device Manager then check in BIOS to see if the WiFi has been disabled.
Start the laptop and then press F2 before Windows boots.
Once in the BIOS menu, select the Security tab and find the Wireless Network Interface setting. Ensure that it is set to Unlock
View the options in the right pane of the screen on which keys to use if you have to change it..
Here is an image to show what I mean.
(click on image to enlarge for better viewing)
Punteggio 3
7 Commenti:
Hello jayeff. Thank you very much for the reply. I don't have access to my laptop at the moment but I will try this in a few hours as soon as I am home. I will let you know how it goes!
da
I have the same problem and I got into the BIOS, but it looks different (I am on Windows 10) and I'm not sure how to navigate to where I'm supposed to go
da
Hi @ Gladius Wrapius,
If you have an Asus X200MA and you are in BIOS use the arrow keys on the keyboard to step across to the Security tab and then down to the WLAN setting.
Use the Enter key to access the WLAN setting and the arrow keys to select the option you want.
You can use the Escape key (Esc) to back out or just press F10 to save the changes and restart the laptop.
If you don't have a Asus X200MA what is the make and model number of your laptop?
da
Hi, I have same issue but with windows 8.1 and 7. I did what you asked still not help.
da
Hi @Avinash Thapa ,
What is the make and model number of your laptop?
da
Mostra altri 2 commenti
First of all, you should go to the BIOS settings, and Ensure that the wifi adapter is enabled on your pc. if it is not enabled, you may enable it. now go to the device manager and check the presence of wireless adapter.
Probably, you don’t have a wireless adapter on your pc, if you have any, than it must not be latest one. that’s why your pc is not detecting the wireless connection. so you should remove the wireless driver from your pc, and install a new driver, for more assistance, you can visit: how to fix asus laptop wifi not working problem
Punteggio 0
If you are wondering about why wont my ASUS laptop connect to WIFI? do not worry, here are the guide to fix the problem.
  1. First of all, you need to switch on the wireless adapter on the ASUS laptop.
  2. Go the network settings, here you need to disable the network adapter for a while. now enable the wireless adapter.
  3. Sometimes, Asus laptop won't connect to the wifi network because of the Device manager. so you need to update the username the wireless driver.
  4. Let's uninstall the wireless driver, and then re-add the asus laptop.
once you will make these changes into the asus laptop. it will let you fix the problem.
Punteggio 0
Aggiungi la tua risposta
Dburns sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 22
Tutti i Tempi: 18,039
