Salta al contenuto principale
The Brother MFC-490CW is a all-in-one color inkjet printer released in July 2009.
Brother MFC-7860DW not turning on
My printer after being unplugged then plugged back will not turn on, I’m wondering if a fuse is busted, I need help to open it and check it or how to troubleshoot
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Risposta Più Utile
Hi @otepd ,
Try this solution I've provided for a Brother MFC -J4510DW and see if it works on your printer also.
My Brother Printer EMFC-J4510DW won't turn on
According to the comments in the Chosen Solution it has worked on a lot of different Brother printers, both laser and inkjet models
Punteggio 2
1 Commento:
Works for MFC-J5720dw printer - resets to factory default though
da
I found that these brother printers are very fussy about where they are plugged in.
First - Un plug it and wait 60seconds
Second - Plug it its own wall outlet, not a extension strip
Hit the power button, it should start up.
- James
Punteggio 0
Aggiungi la tua risposta
Tep D sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 15
Tutti i Tempi: 10,650
