Salta al contenuto principale
Device repair and troubleshooting guides for the HP Pavilion 13-s128nr x360, a consumer 2-in-1 laptop by HP released in September 2015.
How can I upgrade the RAM?
I want to know if I can do it and, if so, how to upgrade the RAM memory of my computer. Specifically I want to know the steps I need to follow and what kind of memory I need to buy.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Hi @maupalo
Based on crucial website, there seems to have options to upgrade your computer RAM
http://www.crucial.com/usa/en/compatible...
Your HP - Compaq Pavilion 13-s128nr x360 Convertible
system specs as shipped
memory
Maximum Memory:8GB
Standard Memory:8GB removable
Slots:1 (1 bank of 1)
To confirm before you proceed to purchase the memory, shut down the laptop and flip to the back,
open up the screws behind to expose the mainboard, you should be seeing RAM slot compartment.
Remove the previous memory and add in the new one.
Check on the PC shops, which is selling RAMs, they might either help you to upgrade the RAM for you complementary or at a small fee, if you are not confident to do the job.
Punteggio 1
Parti e strumenti correlati
Aggiungi la tua risposta
Mauricio Palomares sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 12
Tutti i Tempi: 771
