Salta al contenuto principale
iMac Intel 27" EMC 2309 (Late 2009, Core 2 Duo 3.06 or 3.33 GHz) ID iMac10,1, EMC 2374 (Late 2009, Core i5 2.66 GHz or Core i7 2.8 GHz) ID iMac11,1
upgrading to a SSD
I have 27" Late 2009 iMac.
Can I replace original 1TB HDD with 1TB SSD?
Update (03/24/2018)
My only lingering worry is how to handle temperature sensor for the HDD.
Obviously SSD will not have temperature sensor, so what should I do with the temperature sensor for HDD?
Questa è una buona domanda?
Punteggio 0
1 Commento
There is external sensor on the kit to put it on top of ssd.
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Sure you can! Follow this IFIXIT guide: Sostituzione hard drive con SSD iMac Intel 27" EMC 2309 ed EMC 2374 da 27" and here's the needed tools and parts: iMac Intel 21.5" and 27" (Late 2009-Mid 2010) SSD Upgrade Kit
Immagine Upgrade the storage and improve boot time and read/write speed in your iMac Intel 21" and 27" Late 2009-Mid 2010 with this SSD upgrade kit.
Prodotto
$99.99
Punteggio 2
Yes you can do it if you can afford it,
But the 1 tb SSD will be little expensive and a caddy to fit it...
You can buy a smaller ssd and a dvd to hdd caddy and replace the dvd with new ssd (depending on your time)if you are not using the dvd any more...
Punteggio 0
3 Commenti:
Actually the one iFixit was selling (out of stock now) was not that bad on price: [prodotto collegato mancante o disabilitato: IF107-132]
da
The kit cost for a 1 TB is $389.99
da
Yes , iFixit prices is good , and the 500gb ssd kit is in stock!
You can make you old one Usb external.... and keep your dvd drive!
da
Aggiungi la tua risposta
ikim20012 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 542
