Salta al contenuto principale
The Singer EZ-Stitch Chainstitch Sewing Machine is meant to help beginners create their own fun and creative projects. It can be used to assemble crafts, clothing, pillows, accessories, and more.
Thread gets stuck in machine
My singer machine has thread that gets tangled in the machine. I have gotten it out following the book, but it happens again every time I try to sew. I can’t use it at all. I bought it at least 10 years ago & didn’t use it for the first couple years, then we moved. I tried using it & had that problem immediately. I asked my sewing teacher & she told me it would cost more than the machine is worth to fix it. I can’t afford to buy a new one. I picked it up for like $115 at Target. Not the highest model. I also followed instructions for threading.
I have a different model than chosen. It’s a much better machine than this.
Questa è una buona domanda?
Punteggio 0
3 Commenti
Its not the machine pictured. I have a full size machine.
da
@magecat any idea what model your machine is?
da
It’s a much better machine than the one pictured. It has several stitches. There is a bobbin beneath the plate, none on top.
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Is yours a chain stitch machine like the one pictured, or does it have a bobbin beneath the plate as well as a bobbin in the top?
I wrote up all I know about sewing machines at https://wiki.restarters.net/Sewing_machi... - perhaps the tension is wrong, or the needle is bent, or the timing is out.
Punteggio 2
Preparati per le riparazioni future
Aggiungi la tua risposta
ladycerridwyn sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 6
Tutti i Tempi: 1,387
