Salta al contenuto principale
La macchina per cucire a punto catenella Singer EZ-Stitch è pensata per aiutare i principianti a creare i propri progetti divertenti e creativi. Può essere utilizzata per assemblare lavoretti, indumenti, cuscini, accessori e altro ancora.
Thread gets stuck in machine
My singer machine has thread that gets tangled in the machine. I have gotten it out following the book, but it happens again every time I try to sew. I can’t use it at all. I bought it at least 10 years ago & didn’t use it for the first couple years, then we moved. I tried using it & had that problem immediately. I asked my sewing teacher & she told me it would cost more than the machine is worth to fix it. I can’t afford to buy a new one. I picked it up for like $115 at Target. Not the highest model. I also followed instructions for threading.
I have a different model than chosen. It’s a much better machine than this.
Questa è una buona domanda?
Punteggio 0
3 Commenti
Its not the machine pictured. I have a full size machine.
da Condividi
@magecat any idea what model your machine is?
da Condividi
It’s a much better machine than the one pictured. It has several stitches. There is a bobbin beneath the plate, none on top.
da Condividi
Aggiungi un commento
1 Risposta
Soluzione prescelta
Is yours a chain stitch machine like the one pictured, or does it have a bobbin beneath the plate as well as a bobbin in the top?
I wrote up all I know about sewing machines at https://wiki.restarters.net/Sewing_machi... - perhaps the tension is wrong, or the needle is bent, or the timing is out.
Punteggio 2
Aggiungi la tua risposta
ladycerridwyn sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 3
Ultimi 30 giorni: 16
Tutti i Tempi: 1,766
