Left high beam malfunction
My left high beam does not work on my 1996 Toyota Tacoma even with new lamp and relay. Solution?
Questa è una buona domanda?
@hannibal316 check the socket and see if you have power coming to it when you turn your Hi-beams on. If you lamp is new and the relay is new you are most likely having an issue with the socket/wiring.
Parti e strumenti correlati
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 135
1 Commento
Thanks, will look into it☺
da Hannibal
