On off button sticking and stiff
My on off button seems hard to move and sticks in postioymoved to it used to just spring back by itself
Questa è una buona domanda?
Sounds like a button that is physically stuck, like you said, get a bottle of Isopropyl Alcohol and a Q-Tip, dip the Q-Tip in the bottle, gently swap the switch with the wet end of the Q-Tip (make sure the device is off) switch back an forth. Rinse and repeat until the switch is loose again. Hope that helped!
Where can I purchase a new button. My button came completely off?
Parti & Attrezzi Popolari
constant problem with these cameras. even lubrication does not help
I put new batteries in the camera and won't come on
Ultime 24 Ore: 2
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 41
Tutti i Tempi: 2,586
1 Commento
Tried it made slight difference button still not working properly one of the kids must of dropped it as it still doesn’t move back itself as it use too but thanks for your suggestion will probably have to take it to a repair shops
da gazza b
