Salta al contenuto principale
Model No. A1367 / 8, 16, 32, or 64 GB capacity
How to delete music
I need to know how to delete music on my ipod.
Questa è una buona domanda?
Punteggio 3
4 Commenti
Do you need to delete all the music on your ipod at one time or just a few songs?
da
i dont know about u but just afew songs for me.
da
a few songs needed to be deleted
da
Follow the steps to delete songs on your iPod.
Step 1: Connect your iPod to your computer and open iTunes if it does not automatically start.
Step 2: Select your iPod’s icon from the source list. Click on iPod Options and select Manually manage music and video. Skip this step if you have an iPod shuffle which is already set up to manually manage music.
Step 3: Click on the triangle next to your iPod’s icon to see the contents of the iPod and click on the Music tab.
Step 4: You can hold Shift and select multiple tracks from the list you want to delete at once. And then hit the Delete key or right-click them and choose Delete. Any songs deleted from your iPod hard drive are still be in your iTunes Library folder.
da
Aggiungi un commento
8 Risposte
Soluzione Prescelta
If you are syncing with itunes, while your ipod is plugged into the computer go to the Music tab on the sync options and uncheck the songs you dont want to sync.
Punteggio 5
1 Commento:
i dont have i tunes
da
Parti e strumenti correlati
Acquista tutti
How To Delete Songs Straight from Your Ipod 4th Generation
1. Go to your Music App
2. Go to a song that u would like to delete
3. Then Slide your fingers across the song
4. After u slide your fingers you should see a RED DELETE Button and TAP Delete
AND THIS HOW U CAN DELETE MUSIC STRAIGHT FROM YOUR Ipod
  • If you go to your Settings and Tap General and CLICK About and It does give u back your GB
Punteggio 5
It's quite easy
Method 1: Delete songs directly from your iPod Touch:
Open the Music app on iPod touch > Choose the Songs tab > Find the song you want to delete > Slide over that song and you will see a red "Delete" button > Click it to delete songs from your iPod touch.
Method 2: Delete iPod Touch songs using iTunes:
Plug your iPod to your PC or Mac and click on the "Music" icon that is at the top left of the application in your iPod. Click the check mark to the left of any song that you want to remove from your iPod then sync your iPod again, and the songs will be removed from your iPod.
You don't need a third-party program/app for this.
Punteggio 2
You can use iTunes to delete song from iPod. However, I used a tool called Music Clean Up to manage music in my iPod.. Know more here: Music Clean Up.
Punteggio 1
me have no idea i need to know.
Punteggio 0
1 Commento:
can you tell me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me me
da
this is a ipod touch 6 generation if i format it it tells me it cannot fomat it and to use the support help
Punteggio 0
The worst thing in the world is Ipod
Punteggio 0
Hey, I have a really old purple 4th Generation Nano, and I would like to know if anyone knows how to delete songs from it, without connecting it to a laptop, just deleting the songs directly from my iPod. Can anyone help me?
Punteggio 0
Aggiungi la tua risposta
kessa sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 11
Tutti i Tempi: 45,592
