Salta al contenuto principale
Successor to the PowerShot G7 X, the Mark II was released as Canon's flagship model in 2016.
Screen is completely detached
My camera fell and there are no screws keeping the screen intact with the camera, so it's being held with the thin cable, which looks like a film. The film ripped, so now the screen is completely detached from the camera. What do I do??? How much would it cost to get the screen attached back to the camera? Also how much to replace the screws?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Risposta Più Utile
Aminat, I searched eBay for replacement LCDs for your camera. It looks like you can snag one from $25-30 USD that has fully intact ribbon cables. If you are confident in your technical ability, it may not be a bad idea to try yourself. If not, buy the part and a local tech who can swap mobile device and/or laptop screens should have no trouble doing this for you. If you are still under warranty, I'd recommend contacting the manufacturer first as the repair will void any remaining warranty you have.
Punteggio 2
2 Commenti:
and here are the guides to work on your camera Canon PowerShot G7 X Mark II
da
Would you happen to know what you searched when you found the screens on eBay I’m having a hard time finding them. Also having the same issue screen broke off from the camera
da
Aggiungi la tua risposta
Aminat Seriki sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 32
Tutti i Tempi: 2,281
