Salta al contenuto principale
Il telefono allora al top della gamma Samsung, il Galaxy S8, è stato lanciato nell'aprile 2017.
Broken screen. Can not use touchscreen
I dropped my S8. The part where screen is broken still works. But, the rest of the screen, does not work. Therefore, I can't even turn phone off. And, I can't transfer pictures without touching the allow button. It won't let me. Any suggestions?
Questa è una buona domanda?
Punteggio 4
Aggiungi un commento
5 Risposte
Risposta Più Utile
It's probably a little late, but I used Google voice to do things for me when my phone stopped letting me touch the screen. It allowed me to do many things, if you know the lingo it helps a lot. I just said "ok google (...)" with what I needed to get done on my phone before getting a replacement.
Punteggio 1
Parti e strumenti correlati
Acquista tutti
I was able to connect a logitech M557 Bluetooth mouse
Punteggio 1
1 Commento:
How did you do that? I want to use it as a dex with a qi charger.
da
Laura Rogers the only way to fix this is by replacing the display assembly. Use this guide Sostituzione schermo Samsung Galaxy S8 for that
Punteggio 0
You can definitely replace the Glass and LCD with just the glass and LCD, but for ease of repair, may I suggest buying the glass and LCD with the midframe attached. It has a much better end result in how the repair appears cosmetically.
If you're not feeling that risky, look for your local Ubreakifix. Ubreakifix has a partnership with Samsung with OEM quality parts and prices lower than the part is usually listed online.
Punteggio 0
1 Commento:
I had this put 7Juuu
da
Try changing the battery.
Punteggio 0
Aggiungi la tua risposta
Laura Rogers sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 8
Tutti i Tempi: 22,866
