Salta al contenuto principale
The TI-84 Plus CE is a graphing calculator released in Spring 2015 by Texas Instruments. It includes a 2.8 inch color screen, USB port, apps, storage, and a 1200 mAh battery.
Why is part of my screen black?
Part of my screen is black-blocking numbers-, what is the problem and how can i fix it?
Questa è una buona domanda?
Punteggio 2
8 Commenti
Are the pixels dead? Or just not working while calculating (working when graphs are drawn).
da
@ulees Everything in the calculator works, i just have a big black half circle sticking out from the side of the screen that’s blocking numbers
da
@summerrose Is it dead pixels or something between the glas?
da
@ulees i actually don’t know, what would be the solutions for both problems?
da
@summerrose There is one solution for both problems and it's warranty. If you don't have it then there isn't solution for dead pixels problem. If it's something in the between of screens you can teardown your device and try to remove it. I doubt that is the last one.
If this helped please let me know so i type a full disclosure in answers tab so people can find it easier .
da
Mostra altri 3 commenti
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Hello,
so me and OP of this post resolved the issue in the comments so if you don't mind reading all that.
If you are a little bit lazy just read the last two it contains it all.
Thanks.
Punteggio 0
Preparati per le riparazioni future
Aggiungi la tua risposta
Summer Rose sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 20
Tutti i Tempi: 3,432
