Salta al contenuto principale
The EOS 6D was released in 2012 as Canon’s first consumer-level, full-frame DSLR. It comes pre-equipped with a 2.75”x2” LCD viewing screen, a GPS antenna and wifi connectivity.
What connector is this?
Does anyone know what the 10 pin connector is that sits behind the rear rubber piece on the right side of this camera? I'm assuming it's some sort of service port but curious to know if there's any ability to interface to it. Looks like most Canon DSLRs have some variation of this connector (number of pins varies)
Questa è una buona domanda?
Punteggio 0
2 Commenti:
I see the SD card slot. It has 10 pins and is on the right. Not quite sure where I'm looking at.
da
sorry i should have been more specific. On the back of the camera there is a rubber grip that goes from the top of the camera, around the rear dial. If you pull that piece up, it exposes this connector.
da
Aggiungi un commento
1 Risposta
Here is the manual.
http://gdlp01.c-wss.com/gds/9/0300004019...
Are you referring to HDMI mini or the charge/data port?
Punteggio 0
Parti e strumenti popolari
Aggiungi la tua risposta
Dan DiGregorio sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 277
