Wheel on upside down
I installed one of the front wheels upside down. How can I remove and put it the correct way?
Questa è una buona domanda?
Ottieni un rapido accesso alle guide, ai componenti e alle risposte per i tuoi dispositivi
Take the wheel off by reversing what you did to put it on. Turn the wheel around and put it back on.
These guide may prove helpful
If it is a front wheel, there are two black plastic tabs, one in the front, and one in the back. Use a large pair of vise grips or pump handles to gently depress both tabs at the same time, and the wheel will slip right off. reverse teh arrow and reinstall the correct direction.
Get someone strong basically cause im still tryng to get it off…..2 weeks riding crooked…
I did the same thing and vice grips are the solution, but it takes a few tries. Don’t give up!
I don't have vice grips
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 18
Tutti i Tempi: 10,976
