Salta al contenuto principale
The Summer Infant 3D Lite is a stroller that features an ultra-lightweight design and easy storage capabilities.
8 Domande Visualizza tutte
Wheel on upside down
I installed one of the front wheels upside down. How can I remove and put it the correct way?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
4 Risposte
Risposta Più Utile
Take the wheel off by reversing what you did to put it on. Turn the wheel around and put it back on.
Punteggio 2
1 Commento:
These guide may prove helpful
da
If it is a front wheel, there are two black plastic tabs, one in the front, and one in the back. Use a large pair of vise grips or pump handles to gently depress both tabs at the same time, and the wheel will slip right off. reverse teh arrow and reinstall the correct direction.
Punteggio 2
Get someone strong basically cause im still tryng to get it off…..2 weeks riding crooked…
Punteggio 0
I did the same thing and vice grips are the solution, but it takes a few tries. Don’t give up!
Punteggio 0
1 Commento:
I don't have vice grips
da
Aggiungi la tua risposta
Terri Montoya sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 22
Tutti i Tempi: 10,970
