Salta al contenuto principale
How do I exit DnX mode?
While trying to reboot my tablet I believe I did something wrong and now all it shows is
Entering DnX mode.
Waiting for fastboot command...
How do I exit this mode? I tried holding the power button but it just goes right back to this.
It's a Nextbook Ares 8
Model number NXA8QC116R
Any help would be appreciated.
Questa è una buona domanda?
Punteggio 11
10 Commenti
Same here some times it would turn on and it would be in safe mode and 5 minutes later it would shut down and show its battery charging picture with a ? In it and it would say battery unknown and go back in dnx mode and it seems like every time you put a micro sd card in it goes in dnx mode and if u take it out it will not turn on or work at all until you put the sd card back in right now I am on my computer.
da
Can you download an app for it
da
I have a ares 8 and need help. The TWRP is not working also fastboot commands are denied. las3@nauta.cu
da
Mine still won’t work! I don’t know what to do!
Can someone tell me what to do? I tried everything!
da
Next book ares 8a dnx fastboot mode
da
Mostra altri 5 commenti
Aggiungi un commento
7 Risposte
Soluzione Prescelta
Try this,
- Hold volume up for 15 Seconds,
-While holding volume up, press and hold the power button until tablet turns off
-Release volume up button
-Release Power Button
Punteggio 13
12 Commenti:
I did that and it turned off, but I didn't see the Nextbook logo like I usually do when it shutdown and when I turned it back on it still said Entering DnX mode.
da
this didn't work for me
da
Worked on my Lenovo Yoga Book. Thanks!
da
my nextbook is doing the same, when it does this, on a computer, when you plug it in to the computer, it will say that a driver is unavailable. that means that somehow, you'll have to install a driver, which could brick the tablet if not done right.
da
Yay!! It worked on my Ares 10. I wish I could reset to factory, but that is how I ended up with the DNX mode...
da
Mostra altri 7 commenti
Parti e strumenti correlati
To get to recovery power on, once nextbook logo appears push and hold volume down. When you select recovery and push power to select, it will come up with a droid and exclamation mark says no command, hold power and push volume up at same time and release. This takes you to menu to wipe cache and reset to factory! Hope this helps!
Punteggio 2
1 Commento:
I spent 4 hours looking for this answer , you get a gold star and should move to the head of the class
da
What I did was hold down volume up and power until it goes to a black screen then hold down the volume up and power button while it try to boot you will then see the screen shown below should be a recovery screen use volume up and down to navigate and use the power button to then select reboot system now it’s should then have some yellow text at the bottom and boot up
Punteggio 2
So I found out that there's no fixing it,cause the OS has been erased,which means…you'll want a new tablet(unless bricked tablets are your thing)
Punteggio 1
I get to the Android and exclamation mark with ‘no command’. Continue as instructed. The nextbook powers down and I have to power it back up. It returns to the password screen with no change.
Punteggio 1
Worked thank you so much
Punteggio 0
that was all my carot time &&^&@*@!!!!!!!!!!1
Punteggio 0
Aggiungi la tua risposta
Josh sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 27
Ultimi 30 Giorni: 94
Tutti i Tempi: 22,185
