Salta al contenuto principale
7.9 inch display / Model A1432 / Available in black or white / Announced October 23rd, 2012 / 16, 32, or 64 GB capacity
Ripped tape from LCD to Speakers, is this a problem?
When removing the LCD, I tore the tape while trying to remove it.
Its the pieces from the LCD along the bottom onto the speakers.
Are those essential for electrical contact?
Thanks
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Do you mean the tape at Step 45 of this guide?
It's not ideal but I don't think it makes a lot of difference either way. Sometimes the tape just won't adhere properly (like during a second repair) and it causes no issues. So I doubt the tape being torn would cause any issues.
Punteggio 2
2 Commenti:
That's it, thank you.
I'm just concerned because now the home button isn't responding.
Maybe it's the new digitizer assembly?
da
Probably, however there are a lot of gotcha's when it comes to properly assembling a mini digitizer. Make sure the bottom of the digi looks like this picture (Sostituzione gruppo pannello anteriore iPad Mini WiFi). If you see exposed contacts like on Step 62, you need to cover those with an anti-static tape (Kapton).
da
Aggiungi la tua risposta
David sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 98
