Salta al contenuto principale
Numero modello A1707. Rilasciato a giugno 2017, questo MacBook Pro adotta processori Kaby Lake fino a Intel Core i7 quad core da 2,8 GHz con Turbo boost fino a 3,8 GHz.
I need to replace the screen. Can you make a tutorial?
theres a black line down the left side of the screen and I need to replace it.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
It's under warranty. Take it to Apple!
Punteggio 1
3 Commenti:
I fear he banged his system so there is a visible dent on the lid which would void the standard AppleCare warranty coverage but with AppleCare + they will give him a break. AppleCare protection plan
da
@danj I did not read into the question anything about a dent.
da
@mayer - I didn't either, its just conjecture given the issue of a black line.
da
Preparati per le riparazioni future
Acquista tutti
Ouch! Sorry you got a bad display ;-{
Have you tried locating the needed part yet? So far whats available is quite expensive! Retina MacBook Pro 15" Complete Display - Silver $1,232.60 US.
I would recommend you see what Apple charges for a replacement. If you have Applecare + before you go in it will be cheaper <hint!>
AppleCare+ for Mac
"Coverage for up to two incidents of accidental damage, each subject to a service fee of $99 for screen damage or external enclosure damage, or $299 for other damage, plus applicable tax"
Punteggio 0
1 Commento:
For reference review the steps in replacing the older system: MacBook Pro 15" Retina Display Mid 2015 Display Assembly Replacement. Unlike the older models which used a hollow hing to pass the lines from the display this series uses the middle clutch cover at the entry point. There are two compression connectors that break the ribbon connections.
da
Aggiungi la tua risposta
Brandon Waddell sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 10
Tutti i Tempi: 198
