Salta al contenuto principale
Rilasciato il 19 settembre 2014, è la versione con schermo più grande (5.5") dell'iPhone 6.
Home Button causes LCD to shut off when I connect it to Motherboard
I recently got a 6 Plus, i replaced the Digitizer and Lcd,everything was fine. Now it seems to have a home button issue. the actual home button was fine and salvaged perfectly, but the ribbon cable that connects to the home button was broken. I ordered a replacement backplate shield with ribbon cable attached it seemed to be pinched(at the top of the shield where the ribbon comes out to plug into the board when i got it) I installed it to see if it would make any difference. The touch id does not work which is not my issue(It is the original home button, not original backplate and ribbon) Everything seemed to be working normally for a couple hours, until i noticed a bright spot on the top right corner of the screen, so to be safe i took the phone apart to see if i could notice anything out of the ordinary;which i cant. THE PROBLEM IS- when i went to put together my phone the lcd will only come on if i leave the home button unplugged, if i plug it into the motherboard the screen will not come on.I checked for anything behind the back plate and found nothing, so i closed it up and put it back together. .....ps if leave the home button disconnected the phone starts normally but have no access to home button since its not plugged in. When the home button is connected the LCD will stay black, and cant be fixed in recovery mode, it gives me "error 4014"Any ideas what this could be? THANKS
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Change the faulty flex that you've used on the phone, it was pinched when you got it you then probably straightened it and then adjusted it more to get rid of the pressure mark so it's been over stressed change the flex to another one... if the touchid worked and the home button wasn't damaged then a good quality flex should make both the button and the touchid work :)
Punteggio 0
1 Commento:
Thank you so much for your reply! I am awaiting my replacement for the broken one. I will let you know how it goes when i receive it! Thanks again
da
Preparati per le riparazioni future
Acquista tutti
Aggiungi la tua risposta
TomB sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 51
