Salta al contenuto principale
Modello A1311 / Metà 2010 / Processore Core i3 da 3,06 e 3,2 GHz o Core i5 da 3,6 GHz
Infos on how to exchange the HDD for an SSD as primary and only drive?
Hi everyone,
I just bought EMC 2389 iMac for dirt cheap on eBay and it's glorious!
Perfect condition and little to no yellow tint!
Apart from being noisy, the HDD in combination with the other hardware seems to be some sort of a bottle neck...
I've already learned that I would need some sort of thermal sensor cable if mine was a 2011 model... my question is, what parts exactly do I need to replace the HDD for anSSD and eliminate the HDD altogether... and what SSD would you recommend?
I'm sure many of you have done exactly that...
Thanks!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Well it's a bit more complicated than just swapping things about.
First I wouldn't take the working HD out. But instead add the SSD as a second drive! Here we'll alter the boot drive from the current HD to the SSD so you'll get the speed you are looking for. Here's the IFIXIT guide you'll need to follow: iMac Intel 21.5" EMC 2389 SSD Dual Drive Installation. Here we are giving up the optical drive for the SSD unit using this adapter frame: 12.7 mm SATA Optical Bay SATA Hard Drive Enclosure. That way you also hang onto the HD for your deeper storage needs
If you don't want to give up your optical drive then swapping out the HDD will require a few pieces as the HD in this system is a 3.5" unit and the SSD is a 2.5" unit so you'll need an adapter frame. You'll also need to replace the built in HD's thermal sensor your systems heat management system requires. Here we'll use OWC's in-line thermal sensor. As you need to buy it I've added the OWC frame you'll need.
here's the IFIXIT guide you'll need to follow: iMac Intel 21.5" EMC 2389 Hard Drive Replacement
Immagine Increase the storage space in your computer by replacing the optical drive with a second SATA hard drive or SSD.
Prodotto
iMac & Mac mini Dual Drive Enclosure
$19.99
Punteggio 2
2 Commenti:
For the SSD I would go with a Samsung as your system is only SATA II (3.0 Gb/s). You'll need to make sure what you get can run at this slower speed. Many today are fixed SATA III (6.0 Gb/s) units.
da
Wow. Thanks for the quick and detailed answer! I'll check those things out.
Again, Thank You So Much!!!
da
Preparati per le riparazioni future
Acquista tutti
Aggiungi la tua risposta
Jay Heritage sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 74
