Salta al contenuto principale
Guides on how to fix and or repair common issues on the 1995-2002 3rd generation Toyota 4Runner. The 3rd generation 4Runner is a body-on-frame truck-based SUV with Independent Front Suspension (IFS) and solid rear axle with coil springs in the front and rear.
How to tighten Shift Linkage
How do I tighten my shift linkage.
Questa è una buona domanda?
Punteggio 0
1 Commento:
@dano1971 what exactly is going ton with your linkage (AT or MT)?
da
Aggiungi un commento
1 Risposta
Its a AT, My shifter is very sloppy and today I could'nt you get the key out of the ignition I couldn't put it in park all the way. I have a check engine light on and the code is p1780 I changed my neutral safety switch. But the light stayed on.
Punteggio 0
Parti e strumenti correlati
Aggiungi la tua risposta
Daniel J. Miles sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 485
