Salta al contenuto principale
Repair information and guides for corded and cordless power drills.
How do I open them and cell replacement
These two old Makita 1434 drill batteries have surpassed the end of their life. I was trying to get a look inside so I could replace the cells but the case has no screws, look at the pictures. There aren't any under the label either.
Their Ni-MH, so can I replace them with Li-on? As long as their the same type of cell (possibly C) it should work?
Thank you.
https://drive.google.com/file/d/15C4ws05...
https://drive.google.com/file/d/1pHSdh8r...
Questa è una buona domanda?
Punteggio 5
2 Commenti
Just a thought, after you get case apart(sonic welded/glued) take lots of pic's to aid in proper reassembly of contacts/wires/etc.
da
@oldturkey03 I'm still working on an answer to this...
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Press the button on the side of the battery and pull:
https://www.amazon.com/s/?ie=UTF8&keywor...
UPDATE
LMGTFY
well there are about 8 videos on how to do this on just the first page of my search.
"can I rebuild a cordless drill battery"
Here's one: https://www.youtube.com/watch?v=eCnz9xSt...
Punteggio 4
6 Commenti:
I know I can get them new, but it's cheaper to replace the cells and get more capacity.
da
Updated with Pictures.
da
@pccheese thanks for the accepted answer and the nudge over the finish line ;-)
da
Congratulations Mayer!!
That's quite an accomplishment and other than @oldturkey03 , it's (500K) pretty much out of reach for a long time to come.
da
@mayer congratulations buddy! This is an awesome achievement!
da
Mostra 1 altro commento
Parti e strumenti correlati
@pccheese sure you can do that. here is a pretty good example on how to. Make a guide for iFixit so I have something to go by when I repair my battery
Punteggio 4
Aggiungi la tua risposta
George A. sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 27
Tutti i Tempi: 4,179
