The battery cover is not opening
The battery and sd card cover will not open. It is stuck closed. Can you please advise?
thanks!
Questa è una buona domanda?
thanks!
@geefamily , GeeFamily, The link below shows how to open battery door. If quite stuck, use a heat gun/hairdryer to heat up around the battery compartment door latch area(carefully heat, not excessive) and then try opening may have to pry a little while sliding/pushing the buttons to open position. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Ultime 24 ore: 2
Ultimi 7 giorni: 7
Ultimi 30 giorni: 31
Tutti i Tempi: 3,110
